Old 12-24-2015, 10:36 AM
Marklew Marklew is offline
Default Storage after inspection, whole or parts?
I have found a 0-360 that has been sitting for over 20 years in an A&P's shop. No logs but at a good price.
I am going to have the case, crank, cam ect inspected.
My question is should I completed the overhaul and fill with oil and place on a engine stand and rotate every few weeks, or leave the inspected parts as is and finish the rebuild later? I estimate not needing the engine for 3 to 5 years.
Thoughts?
Mark
Old 12-24-2015, 10:46 AM
Mel's Avatar
Mel Mel is offline
For best results, do not build the engine until you are ready for it.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-24-2015, 11:17 AM
cajunwings cajunwings is offline
Default Engine
I'm with Mel. Build when needed. Corrosion proof and monitor for now. Easier to store too.
Don Broussard
RV-9 Rebuild in Progress
Old 12-24-2015, 11:28 AM
Thoughts?
Mark
Mel is right. However, if you're gung-ho to do something, disassemble the engine and send the parts out for inspection/service. When you get them back, they will be clean and in sealed packaging. Put 'em in a closet or something in conditioned space (not the garage or hangar) and they should remain clean and corrosion free for years.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-26-2015, 09:28 PM
Store as parts then. thanks for the info.
Mark
