I would say your static system is fine. Your system is allowing the altimeters to operate properly. Blockage would impede the altimeters from changing readings freely. Further, you confirmed that your altimeters are matching your encoder, providing a cross-check, assuming you are using a blind encoder and not a feed from the Dynon. It is possible that you have a leak in the static system, as this could give some variance in reading in flight, as you will be given cabin based pressure. In theory this could be adjusting for your error when not in motion.
It is possible that your field did not have a true 30.48 pressure and was different from Pensecola's. It was also possible the Pensecola's altimeter had not been updated recently for changes. I believe that ATC does it's conversions from Pressure altitude based upon the reported altimeter, not actual. I fly from an uncontrolled field and set my alt based upon field elevation. I often get an altimeter reading from a nearby tower that is different. I also would not assume that the Cessna you observed was accurate. Better to check against a barometer.
Larry
