Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #11
Old 12-21-2015, 08:12 AM
jclark jclark is offline
Originally Posted by RV8iator View Post
If you tun off everything, or lose everything, the ONLY thing now illuminated will be the Mini with big flashing notice for 45 seconds screaming, HEY, PUNCH ANY BUTTON TO STAY ALIVE....
There is NO, turn off button on the flashing screen.
I don't see why you all are creating a problm that doesn't exist here.
If some of this is not tongue in cheek, I too was wondering what the real issue here was (aside from documentation).
Is there a different mode of operation that is preferred or desired?
<<This is not challenging anyone, just curious. I assume that if there is a much better mode that GRT can (and might) add it.>>
As mentioned (though not out in the documentation yet ... I hear that that is being worked on) the operation is IF all power goes away for whatever reason, you get a BIG message that IF you want it to KEEP running on battery, press any button. If you don't look at it for 45 seconds and don't touch it at all, it powers down.
There is also a battery charge indicator in the upper right corner.
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 12-21-2015, 08:33 AM
Icarus Icarus is offline
Default NON-ISSUE
If you need your efis in a mode of flight in order to keep the shiny side up, I am next to POSITIVE you will notice the big screen blink off and notice the Mini lit up. It would have to be an exceptionally bad instrument scan to miss this.
No big deal for me, this is how the older dynons operated as well, hit a button to stay alive. I'm considering selling the D2 and putting a GRT Mini in my -4 to supplement the G3X...if you feel like selling your Mini you know where to find me!
Paul M.
Fayetteville, NC
Airport Bum
RV-4 / PA28-180
Old 12-21-2015, 10:51 AM
The functionality of the Mini is very close to that of the legacy Dynon equipment. I suspect most of the conversation here reflects the thoughts of two camps - those who have flown with the equipment, and those who have not yet had the joy of doing so.
As has been pointed out here, an in-flight power failure will present a really, really obvious pilot decision point. When all the other boxes have gone black you're going to naturally poke a button on the Mini to keep it going. It becomes as instinctive as punching the Master Caution Acknowledge button - you just do it as part of your emergency recovery procedure. It will become muscle memory.
The way we train ourselves to develop this muscle memory is really quite straightforward. Every time we shut off the master switch, we are going to see the "battery power" message come up on the Mini. We will become habituated to seeing it appear. We will also become habituated to either hitting a button to keep the Mini alive, or to letting it die after the 43 second timer expires. After only a few power cycles on our panel I was already accustomed to this mode of operation. It really, really isn't a big deal.
For those who perceive this method of operation as a safety of flight issue, it may be worth your while to install an Essential Buss and corresponding backup battery. This would allow the pilot to see the main buss fail, then see the Mini pop up its battery operation warning screen. If the pilot opts to continue operations the pilot can then make whatever switch settings are necessary to activate the Essential Buss. If no Essential Buss is present, the Mini's internal battery acts like an Essential Buss - all it requires is one button push to activate that Essential source of energy to keep the EFIS functioning.
Old 12-21-2015, 04:42 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
There are two major differences in all Dynon EFIS systems that have backup batteries from what we read described by the OP:
1) They do not power down in flight without a button press. They only count down when on the ground. In flight, you get a STAY ON and POWER OFF button that persist until you hit one.
2) If they do turn off, you can turn them on by holding button #1 for two seconds. No external power is needed to get them to boot. In fact, many people boot them off the internal battery when they get in the plane before they turn the master on.
Remember, your EFIS might lose power because the fuse, circuit breaker, wire, or even internal power supply fails. The rest of your panel might stay lit up.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 12-21-2015, 10:40 PM
Thanks "dynonsupport". Good info.
Got this from GRT tonight ... (theirs does NOT power down in flight either).
It can't be turned on with a button. Only external power can turn it on. (The hardware works this way and can't be changed by software.)
If you are "in flight" the auto-power-down function is inhibited. You will get the external power loss alarm and that's it. If you land long enough for the system to transition to "not in flight" mode (20 sec) while on battery, then the auto-power-off function will reactivate and you will get the 45 second auto-power-off notice.
Just FYI to those who were seeking answers.
James
James E. Clark
Columbia, SC
APRS
Old 12-22-2015, 05:32 AM
jthocker's Avatar
jthocker jthocker is offline
Well, it works as advertised! Thanks to all for their comments, especially Widget and "Cool Breeze"!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 12-22-2015, 06:55 AM
Chkaharyer99 Chkaharyer99 is offline
Dang, that looks really good.
What's the hole under the radio stack eventually going to house?
Charlie
RV-8
Old 12-22-2015, 08:50 AM
That's one puurrdy panel! :-)
"CB"
James E. Clark
Columbia, SC
APRS
Old 12-22-2015, 09:00 AM
KatieB's Avatar
KatieB KatieB is offline
They didn't have the battery option finished by the time I left GRT, otherwise this would be in the manual. Glad y'all figured it out.
Katie Bosman
RV-3B sold, but flying!
Next project: ???
Builders gonna build...
Old 12-22-2015, 09:42 AM
SteinAir SteinAir is offline
Rumor has it some double secret airshow technology of some sort...but I guess we'll have to watch one of their shows to find out!
Stein
