New A model nose gear
Over the last week I have stripped the oleo and found the shaft guide ring was not within tolerance and had allowed the shaft to move forward and aft. This resulted in wear on the shaft. A new longer guide ring has now been fitted and I'm very happy with the result, zero movement.
Tuning with oil levels and nitrogen pressures are now underway. So far I have found 7Wt fork oil and 250Psi of nitrogen gives a fairly good ride while stiffening up as the strut is compressed.
A new gear is going to be manufactured with all the changes and I will detail the build as it progresses. The engineering firm doing the work will draw up the final design and have the parts laser cut and CNC turned so it may take a couple of weeks before anything else happens.
While I have no intention of producing any other than my own I have had people ask about it, so if you are interested send my a message and I will see if we can all get a good price on the new gear.
Mick Haynes
RV7
RV7A
RV10
