Old 12-08-2006, 07:11 AM
prkaye prkaye is offline
Default proseal temp
I'm going to be working with Proseal for the first time this weekend (elev and rudder trailing edges). What temperature does the room need to be at, when workin with this stuff?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 12-08-2006, 08:49 AM
painless painless is offline
I would try to get it as close to 60 or so as you can. The colder it is, the harder it will be to mix/apply. It can get pretty stiff at lower temps.
Set time will also be extended at colder temps.
Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
