12-17-2015, 01:36 PM
Fuel Tank Finger Strainer Install
I'm attempted to install the finger strainer on completed fuel tank but found that at about halfway screwed in, I could no longer use my fingers. I got a wrench out and got another turn or two out of it before it became EXTREMELY tight even with a wrench. I stopped there and tried to install it on the the other tank's uninstalled rib with the same results. Is the strainer supposed to screw all the way down flush? I've got to missing something here.
Ryan
RV-14 In-Progress
Build Site
12-17-2015, 03:10 PM
No.
The fitting is NPT (tapered pipe thread)
Read about installing threaded fittings in construction manual SECTION 5
Paragraph 5.27 on page 05-32 would be a good place to start.....
Scott McDaniels
Hubbard, Oregon
12-17-2015, 03:43 PM
Thanks. No sooner did I post did I had the bright idea to check section 5. Because it is such a great resource, VAF sometimes becomes the automatic go to for questions rather than the manual.
Ryan
RV-14 In-Progress
Build Site
12-18-2015, 03:14 PM
Hmmm...My prehistoric (~2002) -7 kit, and my 1990 era -4 have the fuel pickups mounted on the access plate, as shown in the plans. Is the pictured method for just the -14, or has it changed for all the other models, as well?
Open question to Van's...
If this is a revision to 'current tech', why not use an automotive style 'sock' as the strainer? Much bigger surface area, better pre-filtering, and pretty much self cleaning.
Charlie
12-18-2015, 03:46 PM
It is the pick-up style used on the RV-10 and 14 only.
Scott McDaniels
Hubbard, Oregon
06-02-2016, 08:52 AM
What is your question / what are you not sure about?
Scott McDaniels
Hubbard, Oregon
06-02-2016, 01:33 PM
Originally Posted by control
Am I correct in assuming that because it is a tapered tread, it should not go all the way in, so the first picture in this thread looks ok?
(it just misses some sealant)
Correct.
If it does go all the way in, it is an indicator that something is wrong with either the fitting or the hole it is being threaded into.
Scott McDaniels
Hubbard, Oregon
