Old 12-10-2015, 12:42 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Default preparing engine for a future FP --> CS conversion
Warning - possible stupid question ahead... asking to learn....
I'm planning the build of my engine. I am going to use a fixed pitch aluminum prop for now. The engine core is an O-320-E2A. I want to build it for 160 HP, and with fuel injection.
My accessory case has the mounting point for a prop governor (at the lower right side). The engine has the large front bearings and the crank is hollow in the front. I think it is an older crank, maybe with "sludge tubes"
I think when I want to convert, I can add the governor, the stainless oil line and its fittings, remove the front plug in the crank and add the rear plug.
My question is: for now, with the fixed pitch prop, is it OK to have the stainless steel oil line / fittings installed? I don't know if having that line there and no governor installed would cause oil to flow poorly to the front bearing (or flow away from it).
Thanks for any info,
dave
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 12-10-2015, 01:19 PM
eddieseve eddieseve is offline
When I purchased my engine from Vans I specified FP operation and it was delivered from lycoming with the stainless lines installed.
Cheers
Eddie
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
Old 12-10-2015, 01:27 PM
Thanks Eddie!
I found this excellent post from Mahlon_r that indicates that I could have the stainless line installed for fixed pitch operation:
http://www.vansairforce.com/communit...271#post662271
Marion IA
