Old 12-08-2015, 02:49 PM
Flying again!'s Avatar
Flying again! Flying again! is offline
Default Help With Correct Part Number for O-540 E4B5
I want to replace the stainless steel flex lines for the oil return with the Lycoming tubes. I found a catalog on line that shows the part number for the O-540 model A (68759 for cyl 1, 71737 for cyl 2, and 68761 for 3,4,5,& 6) and models B,C, D (72702 cyl 1, 72703 cyl 2, and 73027 for 3,4,5,& 6).
Unfortunately I cannot find the part number for the O-540 E model. Is it the same as the B, C, D models?
Also, instead of using the Lycoming hose I thought I saw suggestions to use silicon hose with a special clamp that applies even pressure around the hose instead of the normal hose clamp. Is it a good idea to use something other than the Lycoming parts for the hose and clamp?
Thanks for any help.
TJ
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
Old 12-08-2015, 03:12 PM
krw5927 krw5927 is offline
A, B, C, and D here refer to parts "groups". Check out page 44 here.
The E4B5 is group A for the drain-back tubes. This catalog agrees with the part numbers you cited for group A.
Kurt W.
RV9A
FLYING!!!
Old 12-08-2015, 03:24 PM
Thanks Kurt, that makes things a lot clearer!
