Old 12-08-2015, 09:02 AM
AAflyer's Avatar
AAflyer AAflyer is offline
Default Battery Chargers?advice?
Who has a hard-wired plug to accept a battery charger? I'm thinking of installing a plug inside my -8's baggage compartment, and want to put a charger on my Xmas wish list. I see the brand name "Battery Tender" a lot online, and they seem to have exactly what I need, but am not an electrician, so am unsure of all the ramifications of keeping a charger plugged into my Odyssey 680 for long lengths of time.
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
2020 Dues contributed
Old 12-08-2015, 09:20 AM
mburch's Avatar
mburch mburch is offline
I'd start by consulting the battery manufacturer's list of approved chargers. This is the most recent version I could find:
http://www.odysseybattery.com/docume...ersApr2014.pdf
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 12-08-2015, 09:21 AM
Tomcat RV4 Tomcat RV4 is offline
Everything I have heard and read, PC 680 does not like or need any battery tender....Tom
Tomcat RV4
RV4 gone to RV heaven !building Zenith 701
dues paid and worth every penny
Life is uncertain -Eat desert first !
U F O Member since Dec 2017
Old 12-08-2015, 09:23 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
My 10 has pigtails for each battery coming forward through the baggage bulkhead, pretty much like you described. I used a unibit to make a hole large enough to fit the body of the connector through, then found a rubber grommet to fit the hole, and cord. The grommet is split so it can be put over the cord, which also makes it easier to put into the bulkhead hole.
A bit of Velcro on the plug and bulkhead keeps things from flopping around.
I only use these if the plane has sat for a long time, then just overnight to make sure the batteries are topped off. They did get a lot of use when programming the EFIS. I do not keep a charger on the batteries any longer than needed.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-08-2015, 09:28 AM
bhester's Avatar
bhester bhester is offline
Default Do a Search
There is a lot about this in the forums. I think you will fine there is no reason to keep a charger plugged into a PC680 it will degrade the life of the battery. I had one for about 8 yrs. and only put a charger on it once or twice a year for less than an hour each time. Hope this helps.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 12-09-2015, 06:59 AM
AAflyer's Avatar
Thanks for all the feedback, guys. I forgot I had such a capable battery, since I bought it almost 2 years ago. Haven't used it yet. Plan on using a "Power Source" to help me test/program Dynon and VP-X.
Bruce Windom
QB RV-8 N148BW
