Old 12-07-2015, 05:59 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Why is This RV Smiling?
Because she got her prop back and went flying for the first time since late September!
Whirlwind replaced all three blades, machined the hub and put it all back together beautifully. The box they shipped it in is a keeper - ready for the next maintenance cycle, it would be a shame to lose it. I ran it up on the ground after installation, checked for leaks, then took it up over the field for about twenty minutes. Running great, very smooth - but we'll still look for a Dynamic Balance somewhere here in the Reno area. Walt has always done our balance work, but he's a long ways away.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-07-2015, 06:22 PM
Michael White's Avatar
Road Trip!!!
(Besides, you know you need a side-trip to the Hard-8 to get you barbecue tank topped off... )
Moose
VAF #136
Old 12-08-2015, 04:43 AM
Ron B. Ron B. is offline
Paul, I think it's still pissed. I see it as a GRRRRR. 20 minutes isn't enough.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 12-08-2015, 06:23 AM
BillL BillL is offline
Paul, Do you know/can you say what design/material changes were made for this blade connector design to eliminate the failure?
Bill
RV-7
Lord Kelvin:
Old 12-08-2015, 08:20 AM
Danny King's Avatar
Danny King Danny King is offline
Default BBQ fill up
Iron,
I have plenty of room in Hanger 8 for the 3, and a B&B for you. Call Walt.
Sky
Danny King
Beautiful Doll 80434 TT 1675 hours
I0360 A1B6 200 HP
Christen Inverted Oil
First Flight 12 July 2000
VAF Dues current for 2020
Old 12-08-2015, 03:35 PM
Ironflight's Avatar
Not yet - I think these were made pretty much the same way as before, and there are thousands of this type of blade flying. The folks at Whirlwind say this is the first time they've seen this failure, and I am comfortable with what I know to fly these new ones (and do an early inspection).
Hope to see if they do some failure analysis on the originals to see what happened.
Paul
Paul F. Dye
Old 12-08-2015, 03:36 PM
Ironflight's Avatar
Originally Posted by Danny King View Post
Iron,
Sky
Yes....but I have to find the time! Maybe if someone I knew in the area had built a new jet that needed to be tested, I'd have an excuse.....
Paul F. Dye
Old 12-10-2015, 07:56 PM
climberrn's Avatar
climberrn climberrn is offline
Default Balance
Ray Pasch at CXP does prop balance. Did a great job. I bet he would drive all the way out to your place😋 . I'll send you his number.
Joel
P.S. Do you know if the RV74 has the same blade design, i.e. The part in the hub that cracked? Hope not...
Joel
N626JA
RV-7A at CXP
Flying!
Old 12-10-2015, 09:52 PM
Ironflight's Avatar
Thanks Joel - I think I'll have the equipment available to me that will also generate a good artcile for the magazine - but I'd liek to know who has them local as well - good for everyone to know!
Paul F. Dye
