Old 12-07-2015, 10:52 AM
Byron7 Byron7 is offline
Default RV-7A nose gear bolt
Can the bolt be inserted from above and forget about drilling a hole in firewall?
Old 12-07-2015, 11:03 AM
YellowJacket RV9 YellowJacket RV9 is offline
At least in my case, if you tried that the bolt end would hit the firewall; remember, in order to have a few threads showing, that end will stick out farther than the head of the bolt. In fact, with mine, there wouldn't even be clearance for just the bolt head without the hole in the firewall. Certainly no way to get a wrench in there and tighten it.
It really isn't much trouble to make that hole, and would probably be more effort to effectively torque that nut even if you could manage to get it in place.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 12-07-2015, 11:12 AM
Fred.Stucklen's Avatar
Fred.Stucklen Fred.Stucklen is offline
Default Nose Gear bolt
Yes! but you will probably have to create an indentation in the firewall. I used a rounded off 1" wood dowel that I hit with a hammer.... with no hole in the firewall...
Fred Stucklen
wstucklen1@cox.net
RV-7A N924RV Flying (1825 Hrs & counting)
RV-6A N926RV 875 Hrs (Sold)
RV-6A N925RV 2008 Hrs (Sold)
Old 12-07-2015, 08:13 PM
gasman gasman is offline
Yes. Same mount as my 6... Start the nut as soon as there is enough thread. Hold the nut in place as you tap the bolt down. No firewall pounding needed.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 12-07-2015, 08:26 PM
Default Gear bolt
Wonder why Vans had put bolt in upside down. I think no whole better idea.
Old 12-07-2015, 09:02 PM
AlexPeterson's Avatar
When putting the bolt in from the top, use an all metal lock nut as well, they are smaller, and will fit under the mount more readily. The nut has to be started just as the bolt is coming through. Use washers as necessary to keep the threads out of the mount.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 12-07-2015, 09:16 PM
cajunwings cajunwings is offline
Default Nose gear bolt
Have taper pinned 2 "A" models and put the pin in from the top. The rounded end of a broom handle and a dead blow hammer makes a dandy tool to form a dent in the soft firewall for the nut. Work slow and from both sides till it looks right.
Don B
RV 9 Rebiuld in Progress
Old 12-08-2015, 06:46 AM
BillL BillL is offline
Remember, this bolt can come loose and is on your annual check list to put a wrench on it. If it is loose can you tighten it? if it comes loose again, can you replace it? Now is the time to think about this bolt. They have failed, and resulted in moderate to significant damage (nose over).
There is a well written paper on the gear and solutions. I compiled it from a VAF post and will send it to you. Send me your email address by PM/email.
Bill
RV-7
Lord Kelvin:
Old 12-08-2015, 08:16 AM
rvbuilder2002's Avatar
I am not aware of any nose over (I assume that means the same as flip over inverted) that was caused by a broken nose gear leg bolt.
Nose down... yes for sure with resulting prop and possibly engine damage.
It is highly likely that all nose gear leg bolt failures to date were caused by incorrectly installed Nose Stop Flanges as detailed in THIS S.B.
Regardless, the advice to make this bolt easily serviceable is a good one (and the primary reason the plans specify the hole in the firewall and installation of the bolt from bottom up).
Scott McDaniels
Hubbard, Oregon
