Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Autopilots
Old 12-07-2015, 10:06 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default The TruTrak ECO Autopilot really flies!
I know that lots of folks saw Tru Trak?s prototype demo of the low-cost ECO autopilot at Oshkosh a few months ago, and many looked forward to seeing it in action. I got a chance to fly it this weekend with Andrew in the Tru Trak RV-10, and I have to tell you folks ? this is revolutionary from both a cost and performance perspective. For $1,000, you get a two-axis autopilot that will hold heading, track a Nav source, and hold altitude ? the three things we all do with our autopilots about 95% of the time. For a VFR pilot, it is hard to think of anything else that you absolutely NEED. It has good control authority (I couldn?t tell much difference between it and Sorcerer installed in the airplane as well), and a unique feel ? because it flies with trim tabs, rather than manipulating the controls.
And then there is the Envelope Protection ? another cool feature that could very well make a huge contribution to GA safety.
I did a little write-up about it HERE, and there will be a full review in Kitplanes in an upcoming issue.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-07-2015, 09:20 PM
TruTrakAndrew's Avatar
TruTrakAndrew TruTrakAndrew is offline
Default Wonderful time!
I had a wonderful weekend with you and "Ms Louise" :-) thanks for your amazing hospitality! Also, thanks for letting me work on your new project. I don't get to do fun things like that much anymore!
Andrew Barker
Andrew.Barker(at)Honeywell.com
Honeywell
www.BendixKing.com
TruTrak
RV-4 214NY "Carrie Ann"
RV-10 989TS - undergoing complete overhaul!!!
Always flying someone else's airplane too
EAA - 309420
Old 12-09-2015, 11:41 AM
koupster's Avatar
koupster koupster is offline
Default Military 8
Paul,
Please define Military 8 as used in the article you posted. 30 minutes of web searches yielded no answers. My RV 8's are done at some multiple of the 30 degrees specified for Lazy 8's in the FAA PTS. Despite having a military background, I haven't heard of a Military 8 before.
Thanks for all your contributions to our community.
Cheers, David
RV-6A
Old 12-09-2015, 08:59 PM
Ironflight's Avatar
Originally Posted by koupster View Post
Paul,
Cheers, David
RV-6A
"Military 8" is just a not-so-lazy lazy 8 - somehitng less than a pair of wingovers, bt fairly steep.
Paul F. Dye
Old 12-09-2015, 09:12 PM
Kyle Boatright Kyle Boatright is online now
If you're not coming over the top inverted, you're doing it wrong. ;-)
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-10-2015, 12:07 AM
arffguy arffguy is offline
Default Servos used?
As a long time R/C modeler, I would be really curious to know what servos they picked.
Mike F
RV-6A wings/fuselage
RV-3 empennage (extra thanks to Mr. Zilik)
RV-4 Plans only S/N 2938
Cessna 152
Elk Grove, CA
VAF #744 Exempt but paid anyway
Old 12-10-2015, 01:39 AM
DaleB's Avatar
DaleB DaleB is offline
That would be the Cuban military 8, right?
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 12-14-2015, 07:00 AM
Could be the old geazer 8 I do in the 8...very gentle, rather steep, one g, nose up and over and descending and do it again.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 12-14-2015, 09:51 AM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
I learned how to do the military 8 from an F15 pilot this way. Pull nose up, freeze the stick and use rudder only to make the turn. Release backstick pressure once turn is initiated. Wing over and then use rudder only to level the wings. Pull back stick and do the same operation in the opposite direction. We called this a "canyon turn" as it really reduces the radius of the circles needed to form the not so lazy 8. Really a fun maneuver.
Old 12-14-2015, 11:17 AM
Default servos
We are using modified Hitec servos. They are IP67 sealed, ball bearing, metal gear servos.
Andrew Barker
Honeywell
www.BendixKing.com
TruTrak
EAA - 309420
