Old 12-06-2015, 01:46 PM
JOEPILOT JOEPILOT is offline
Default Carb sync?
I'm about to do the mechanical carb synchronization. In the Rotax maintenance manual step 6 says to adjust the idle mixture screws. To me it looks like the only way to accomplish this wold be to remove the carbs. Any thoughts?
Thanks, Joe
Old 12-06-2015, 01:58 PM
Rick_A's Avatar
Rick_A Rick_A is offline
You should not need to adjust the Idle Mixture. You will probably have to adjust the Idle Stops - but just a little bit.
The mechanical sync on mine were pretty close right out of the box using Vans install instructions. It was only when I did the Pneumatic sync that I could see that an adjustment was required.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 12-06-2015, 06:55 PM
Bill_H's Avatar
Bill_H Bill_H is offline
Remember, they rest run the engine pretty thoroughly at the factory.
Old 12-06-2015, 07:32 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Mixture screws should be checked to ensure they are opened 1 1/2 turns...beyond that, they should be fine.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 12-07-2015, 04:54 AM
Dave12 Dave12 is offline
Joe, the engine in my first 12 ran flawlessly out of the box. It ran so well, I did not touch the carbs for 10 or 15 hours. My current mount ripped and snorted, had to be purged 3 times and took hours to calm it down. It now runs smoother than the first one, so be prepared for anything. The 912 is a great engine. I think you are going to like it.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Currently restoring a 1978 Citabria GCBC
Old 12-11-2015, 07:06 AM
Sink Sink is offline
Banned
Once the mixture screw is set on the bottom of the carb at 1.5 turns out it usually never changes. It is spring loaded with an "O" ring so it keeps its set.
Adjusting these screws as written in the manual also includes times when the carbs have been disassembled for maint. so if you are just checking a sync and this was done beforehand it isn't necessary to keep doing it.
Rotax engines can sound okay when running, but can be a ways off for a carb sync. The human ear can not tell the difference unless it is way off.
Always do your carb sync. Cables stretch, parts wear in, pulleys settle in, ect.... carbs can and will get out of sync as a new aircraft breaks in. If you do a full mechanical and pneumatic sync at 25 hrs. then you only need to do the pneumatic sync at the 100 hr. / Annual.
I'm sure Vans has already done a mechanical sync during their aircraft setup which can be checked instantly when you hook up a set of gauges.
I had one 30 year A&P said he didn't need gauges to set a carb sync and he could do it by ear. He was 6" of vacuum off. Use the gauges.
Old 12-11-2015, 03:03 PM
Now that's funny! Reminds me of a mechanic I used to work with about 40 years ago that said he did not need to use a dwell meter to set breaker points, he set them by ear.
Old 12-11-2015, 03:46 PM
DaleB's Avatar
DaleB DaleB is offline
Just his way of making sure he always had repeat business... From people with poor judgment. :-)
Dale
Omaha, NE
Previous RV-7 project (sold)
