Old 12-05-2015, 06:21 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Skyview data log RPM during mag check?
I was looking through some of my old logged data from my flights and I noticed the system wasn't recording the change in RPM during run up. The data log captures data 4 times a second (.25 sec). The Skyview data logger has a RPM L and RPM R column but the data in both are the same. The data logs from my old D180 only had a single RPM column.
The Skyview displays L and R RPM drop fine but doesn't capture it the data log.
Anybody else notice this? Is mine wired wrong? Is the logger not collecting the respective RPMs? Am I having a senior moment?
Stay tuned for the responses from the forum. Same Bat time, Same Bat channel! (references the old Batman TV series for those young builders out there).
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 12-05-2015, 06:52 PM
n82rb's Avatar
n82rb n82rb is offline
Without knowing how your skyview is wired it's hard to tell what's going on. Does each ignition have a pickup or how is it wired.
Bob burns n82rb rv-4
Old 12-05-2015, 07:37 PM
Pmerems's Avatar
Default Wired per Dynon instructions.
The system is wired per Dynon instructions off the starter switch. That is how the RPMs are sensed. Not off a electronic tach sensor on the assessory case. Since RPM is displayed with either L or R mag on or off during mag check I believe it is wired correctly.
Old 12-05-2015, 08:13 PM
vlittle's Avatar
vlittle vlittle is offline
That's the way it works. It displays the maximum rpm. The l and r indications are misleading.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
N941WR's Avatar
N941WR N941WR is offline
What type of ignitions do you have?
The data in the two columns should be the same but both should drop equally as the engine slows during the mag check.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-05-2015, 09:05 PM
RV7A Flyer's Avatar
I see the mag drop on my data logs (looking at them via Savvy Analysis). I believe the RPM comes from *either* the L or the R mag, but not both (which one is primary, I don't know...have to leave that to Dynon to chime in).
Bottom line...works fine for me, wired as per the installation manual.
Perhaps you could post a screen shot of what you're seeing that makes you think it's not capturing RPM drop?
Old 12-05-2015, 09:28 PM
Pmerems's Avatar
Default What I thought I would see
I would have expected to see a "zero" in the RPM column opposite the mag being checked and an rpm drop accordingly. But maybe the L R rpm columns are for a twin engine install someday? Dynon is thinking ahead?
Old 12-06-2015, 04:52 AM
N941WR's Avatar
I'm not sure but I think they may be wired together within the Dynon as mine reports both, even when one of my P-mags is powered off.
The reason I asked about which ignition you have is the P-mags, if installed per the instructions, will put out a tach signal when the P lead is grounded. I don't know if standard mags will do this or not.
Bill R.
SC86 - Easley, SC
Old 12-06-2015, 11:10 AM
n82rb's Avatar
From the install manual
SkyView will display RPM from either the RPM Input Left or the RPM Input Right, whichever is noticed by the SV-EMS-220 first. If the first RPM signal is lost (such as when one ignition source fails, or during a routine mag check), then SkyView will display RPM from the remaining RPM signal. If your engine only provides one RPM signal, connect it to one of the two RPM Input Left pins.
So I am guessing the columns will be the same but there should be a drop shown on only one mag.
Bob burns
Rv-4 n82rb
Old 12-06-2015, 04:29 PM
RV7A Flyer's Avatar
Bob burns
Rv-4 n82rb
No, there's a drop shown when *either* mag is turned off (and the engine RPM drops). It's measuring your actual engine RPMs (albeit via a different method)...whatever the cause of the RPM drop, SV will see it (assuming your actually get an RPM drop on each part of the mag check).
ETA: I just looked at a recent log file, and during the mag check, the two columns show identical numbers, both dropping about 100 RPM during each portion of the mag check (L off, then R off).
Granted it may be taking the *data* from a single input line, but the RPM L and RPM R columns both accurately display the engine RPM during all phases of flight, including run-up (prop cycle, mag checks).
