Originally Posted by n82rb
The lycoming chart showed about .58lbs/bph/hr that's about 15 gal/hr full rich,full power, standard sea level day.l
Bob burns n82rb rv-4
Time out; he's got a fixed pitch prop. .58-.60 is likely a good number range, but you need to find power at his actual takeoff rpm (2200) & full throttle, not full power (2700rpm).
I see around 13-14 gph with an O-320/160 hp. I'm suspicious that it runs a bit richer than Lyc spec at full throttle.
What does the chart say at sea level MAP & 2200rpm?
Charlie
