Old 11-28-2015, 06:51 AM
Far North Texan Far North Texan is offline
Default Best way to make larger instrument holes in existing panel?
I am in the process of saying goodbye to my old Isspro fuel quantity, and oil temp/pressure gages. I am going to replace them with electronics intnl. guages.
The existing holes are 2", and the new guages require 2 1/4" holes.
What is the best way to open these holes up?
An instrument hole punch would be best I think but how do you keep it centered with a 2" "pilot hole"?
No doubt there is a tool for this but I don't happen to know what it is.
RV-6A slow build,
serial # 21681. First flight March 1993
Dec 2019 donation paid
Old 11-28-2015, 06:58 AM
mosquito's Avatar
mosquito mosquito is offline
Default +1 for the punch
I used a punch for this exact operation. Mark the new circle on the panel and get the punch started manually until makes contact with the panel and holds itself in place. I was very worried about keeping it centered but it turned out to be quite simple.
I've also done this operation with nibblers and a file... and that made an unholy mess of aluminum dust. I recommend the punch.
-jon
RV-6 | O-320 | Triple-bladed Catto
Old 11-28-2015, 09:20 AM
thanks much, I didn't know if it would grip and stay in position.
RV-6A slow build,
Old 11-28-2015, 11:53 AM
flyboy1963's Avatar
Default one method.....
I'm no machinist, but if you drill the 4 new instrument screw holes, then use these to attach a sacrificial square of aluminum behind the panel, this will be your pilot hole guide piece.
you can then use the punch, or a more primitive hole saw to cut thru the panel, and slightly into your scrap piece.
File, dremel, finish as needed.
Your local avionics shop may loan you a punch for the standard rental fee ( a case of Big Rock suds, or bottle of rye.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 12-06-2015, 07:53 PM
Aero_Octaveus Aero_Octaveus is offline
Default Rye
Rye - Also known as Crown Royal down south
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
http://garetsrv.blogspot.ca/
Old 12-06-2015, 08:28 PM
bhester's Avatar
bhester bhester is offline
Default Punch
Once that punch starts to bite it is not going anywhere. Go slow.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 12-06-2015, 09:04 PM
thanks for all the input. I did find a hole punch for a good price and have it on order.
RV-6A slow build,
