Old 11-25-2015, 11:13 AM
acam37's Avatar
acam37 acam37 is offline
Default Black soot exhaust tips
We are still very early in our engine break-in. (0320E2G 160hp carbureted) we have about 3hrs in the air and about an hour on the ground. Following the Lycomong break-in procedure for channel chrome bore cylinders. We are still running full rich 75% power at 4000ft. The CHT's are still averaging 370-390 degrees but have dropped from around 400 since the first flight. I guess my question is; is black soot in the exhaust tips which I understand is caused by running excessively rich mixture, normal or is it a sign of improper break-in or a major malfunction? We can't lean the engine because of the still high CHT's.
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
Old 11-25-2015, 12:15 PM
airguy's Avatar
airguy airguy is offline
That's a normal result of running rich.
Old 11-25-2015, 12:19 PM
N941WR's Avatar
N941WR N941WR is offline
Correct!
Keep running at full power and full rich until you get to 10 hours. Once you start learning it, your exhaust will turn grey.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-25-2015, 01:46 PM
acam37's Avatar
Good deal. I was hoping this is normal during break-in. I just hope those CHT's continue to drop to more normal readings.
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
KOCH Nacogdoches
