11-24-2015, 06:57 PM
Different speeds different models
I tried to search this but couldn't find a thread.
It there's one already please link it.
Vans posts estimated speeds on their site for the different models.
I have searched many different tail numbers in FlightAware and although it's not an accurate way to see how fast a plane is, it does show how fast people are flying in the system.
What model do you fly,which engine choice, what's your cruze speed and finally how fast can you go?
Paul
11-24-2015, 10:03 PM
I have:
RV-4
Sensenich metal 2B prop
160 hp
Carbureted
ZFW 1028
Climb summer MATOW from 1000msl 1500-1700 fpm
-cruise 160-165 Kias
Climb winter MATOW from 1000msl 1700-2100 fpm
-cruise 165-170 kias
RV-4 - 0-320 (160HP)
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
11-25-2015, 06:00 AM
Very loaded Question which will get a wide variety of responses
Vans published speeds on his website are not estimates. They are based on flight test data.
FlightAware are ground speeds so very inaccurate to determine how fast someone is flying without knowing the wind speed/direction.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
11-25-2015, 08:02 AM
Not sure why speeds would vary from summer to winter. I understand climb performance varies with temperature. But my fixed pitch speeds are constant relative to RPM.
11-25-2015, 08:05 AM
Originally Posted by plehrke
Vans published speeds on his website are not estimates. They are based on flight test data...
Very true! Plus the prop used can greatly impact cruise speed.
In my case I have an RV-9 tail dragger w/ an O-360 and fixed pitch Catto prop and typically cruise at between 55 and 65% power and see 150 to 160 knots. At 8,000 density altitude and all in (~75% power) it will true out at 174 kts but I never cruise it there.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
11-25-2015, 09:01 AM
200 HP RV-8 Hartzel Blended Airfoil:
165 KTAS @ 8.5 to 7.5 (between 7,500 and 10,500). wot, 2300 RPM, LOP
178 KTAS @12.5 GPH (max cruise)
260 Rocket Hartzel paddle blade:
195 KTAS @ 11.5 to 10 (7.5 and 10.5). WOT, 2300 RPM, LOP
224 KTAS @ 20+ GPH (max cruise)
Both airplanes are pretty "dirty" examples. Some aero cleanup should shift the speed up a little at the same fuel burn.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
11-25-2015, 10:26 AM
They shouldn't be. The prop thrust is tied to air density. For the same reason that your prop thrust is low at 10,000 DA is the same reason that it is high at -1000 DA. The prop is pushing air. The denser the air is, the greater the ultimate thrust produced by moving that air. Cold air is denser than warm air
Larry
11-25-2015, 11:10 AM
My -10 is pretty consistent
At 7,500' and 75% power, my -10 consistently runs 204MPH solo and 200 MPH with 4 adults. I happen to have a two-bladed Hartzell blended airfoil prop...tested as the fastest prop for a -10. Aerosport IO-540 260HP.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
11-25-2015, 12:23 PM
Larry
I'm just reporting facts. Same true airspeed at same RPM's regardless of altitude. Could it be that there is also less drag in thinner air proportional to reduced thrust?
To get back to OP's original question, I usually cruise at 162 ktas at 2450 rpm's and 8 gph rich of peak at 8000 density altitude. At 2700 rpm's I get 178 ktas, gph varies greatly depending on altitude
Rv8 with Superior IO 360 and and Catto 3 blade
Reason: Model
11-25-2015, 12:38 PM
Pier smith
What is your fuel consumption at those speeds/settings with that engine?
