I agree with the other experiences here. It took a fair bit of shim, (something like 1/2 degree on one side and 1-1/2 degree on the other).
It makes a big difference in handling, and also a big difference in tire wear.
But....
The tire wear only occurs with weight on the wheels. Lift the tail up to level attitude (like you were going to do a W&B) and roll the airplane forward several feet --this takes out any stiction effects. Then do the wheel alignment measurements.
It is true that the camber will be different when the gear is lightly loaded, like on a 3-pt landing, but in that case, there is no weight on the tires, so they don't wear.
And fortunately on the RV-8, because of the gear leg design, there is very very little toe-in angle change between unloaded and loaded, so the handling should be fine for 3-pt too -- as much as you could say the handling is ever fine at 3-pt touchdown on the -8
Lots has been written about that already.
