E-trim HS on manual trim RV-7?
Hi all, I have an issue with the horizontal stabilizer on my project and need to replace it. I found a HS for sale but it was built for electric trim. My plane is set up for manual trim. As far as I can tell, the only difference between electric and manual trim as far as the HS is the hole in the spar web for the cable to pass thru which I can easily add. Anything I'm missing?
Matt
Matt K.
RV-7 Tip-up - Flying!
XP Superior IO-360 w/cold air sump, Catto 3 blade prop
Garmin G3X
CFI, CFII, MEI
