Old 11-20-2015, 11:00 AM
flyboy1963's Avatar
Default planning for the new fuel? are we ready?
Something I haven't heard addressed directly; we are going to be putting something like 94 octane UL in our tanks someday not to distant.
1. should some of us planning engine choices stay away from that hot-rodded 0-375 with 9:1 compression?
2. if we now have 8.5 or greater compression, what's the most expedient 'fix' if needed. Shave the pistons, swap the heads for new magical ones......?
....or can all this be fixed with 'simple' computer controlled timing advance software driving our Electronic Ignitions?
surely the engineering crowd mindtrust on VAF has some guidance for us?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 11-20-2015, 11:23 AM
YellowJacket RV9 YellowJacket RV9 is offline
It played a bit of a factor in my choosing a low compression engine, although finding a good deal was a bigger factor. After phase 1 I do plan on experimenting with ethanol free mogas, especially in cruise flight. May also add a vapor return line to reduce vapor lock potential.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 11-20-2015, 11:36 AM
9GT's Avatar
9GT 9GT is offline
I first started experimenting with 90 octane ethanol free mogas in my IO-540 with 8.5 compression ratio by keeping mogas in one tank and 100LL in the other. At cruise altitudes I would switch between tanks and monitor the EMS info and found no noticeable difference between the two fuels. I just replaced my cylinder assemblies and opted to keep the 8.5 compression ratio. I attended the Lycoming Engine dis-assembly/re-assembly seminar Lycoming held held at Airventure a few years ago and the Lycoming tech stated I would be fine running this fuel with the 8.5 pistons.
David C.
Howell, MI
Old 11-20-2015, 12:20 PM
RV6_flyer's Avatar
Default TCDS
The Type Certificate Data Sheet for the certificated version of the engine we use has the Octane the engine was certificated on. If you look at the Superior Vantage 360 engine (certificated clone of the Lycoming 360 with same bore, stroke, and compression ratio) TCDS you will find that some versions were certificated on 100LL and also on auto fuel. (ASTM D910, Grade 100, 100LL or 100VLL ASTM D7547; [Motor Gasoline (R+M/2) (See Note 7)] ASTM D4814, Min Octane 91 (no alcohol)) [My comments: The See Note 7 is a copy paste and I believe that it is a typo and should be Note 6 as I could not find a Note 7 in the TCDS.]
If you check parts manuals for the Lycoming parallel valve 360 and 540, you will find they use the same cylinder assemblies.
The Type Certificate Data Sheet E-274 covers many of the 160 HP Lycoming 320 engines (8.5:1 compression). The carb versions of most of these engines were certificated with Aviation Gasoline 91/96.
When the FAA gets around to approving an unleaded replacement for 100LL, many of us flying RVs will not have an issue using it with the stock or clone Lycoming engines that Van's Aircraft Recommends. Those that ventured off the beaten path will need to do some work on their own to figure out how to get back on the beaten path were most of us are who follow the recommendations of Van's Aircraft are located.
My understand of the unleaded aviation gasoline replacement problem is that the turbocharged and supercharged engines are the ones that have the highest octane need. Finding a fuel that will satisfy the needs of the turbocharged and supercharged engines has been the biggest problem.
The bore on the Lycoming parallel valve 320, 360, and 540 are the same. The 8.5:1 pistons and rings are the same part number on most of the engines. The 320-H2AD engine uses 9:1 pistons. The 150 HP 320 uses a 7:1 piston that ran on the now discontinued 80/87 aviation fuel. IF fuel octane becomes an issue in the future, most of our parallel valve 320, 360, and 540 engines could be retrofitted with 7:1 pistons and run on alcohol free auto fuel. All we would need to do is pull the cylinders, hone cylinders, install new piston and rings then reinstall with new gaskets. (o-ring) The lower compression 7:1 piston and engines are not as efficient as 8.5:1 engines and will burn more pounds of fuel per hour per horsepower produced so it is not an attractive option for me.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-20-2015, 01:27 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Lycoming says...
Lycoming altered their TCDS in effect with this April, 2013 Service Instruction that specifies the same fuels you mention above for the Superior Vantage engine.
http://www.lycoming.com/Portals/0/te...e%20Models.pdf
The differences due to compression ratio are listed in the last table of the SI, for our O-360-A models the auto fuel is specified as 93 AKI octane.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-21-2015, 12:39 AM
paul330 paul330 is offline
UL91 has been available for some time in UK and all the "standard" 8.5:1 Lycomings run fine on it and are approved under SI1070. Rotax prefer it and there is some evidence it is also better for the Lycos.
If I were building now, I would definitely not fit a higher power/compression engine. As mentioned, those with more exotic engines are going to have some work to do eventually.........
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
