11-16-2015, 02:30 PM
Magnesium or Alum Sump on RV-9a?
Getting ready to order engine and was offered an option of a Magnesium or Aluminum sump. The Magnesium is 7lb lighter and $350 more expensive.
Would this be worth it for an RV-9A with recent glass avionics? Note that I am also going to be running a WW-GA200L prop, which I understand is already rather light.
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
11-16-2015, 02:44 PM
That's a question only you can answer - it comes down to trading dollars for pounds. Each of us will have their own point of happiness on that scale.
11-16-2015, 02:47 PM
I'm more concerned along the lines of CG. Am I getting too light up front? Is there a way to calculate this without knowing all the numbers?
11-16-2015, 02:52 PM
$50 a pound for weight saved is a bargain. And seven pounds saved is huge.
Sounds like a great deal to me!
Dave
11-16-2015, 04:38 PM
What engine?
My 9A with a 320 and WW C/S prop required 2 lbs in the tail until it was painted. I would recommend the lighter option.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
11-16-2015, 05:47 PM
It is best to build as light as you can. Then you can add weight where you need it, if you need it.
I have thought about buying the sump and installing it on my O-360, just to drop a few pounds, maybe some day. Now if I could get a magnesium belly replacement for me!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
11-16-2015, 06:09 PM
If the engine is a 360, then I'd say go for the lighter sump. If a 320 engine, then you might need the extra weight up front.
Neal Howard
Airplaneless once again...
11-17-2015, 06:11 AM
Who supplies the Magnesium sump?
Doug Gray
RV-6 completed, flying since July 2010
11-18-2015, 01:41 PM
It seems to me that a lot of 9A's with 320s & FP props (especially composite ones) end up needing more nose weight for optimal cg. Nearing the weighing stage on mine, I'm really curious to see where the cg lands...a little tail-biased for me is not a big issue as I don't anticipate having to carry much baggage. I'd save the $350 and lose bragging rights for having the exotic sump.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
11-18-2015, 01:43 PM
Don't know who the supplier is but Titan is the manufacturer/assembler I am working with that has it.
