Old 11-16-2015, 10:00 AM
rv9builder rv9builder is offline
Default Airbrush recommendations
I'm looking for a small, easy-to-clean airbrush. Any suggestions?
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
Old 11-16-2015, 10:19 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Cheap badger brushes
If it's for small touch up work and not for creating nose art...
The cheapest Badger ones work. I've even used them for Akzo epoxy with less than 1/2 ounce of paint mixed up.
Badger 250 above.
The external mix brushes are the easiest to clean.
Be carful of some of the HF equivalents, their plastic won't take the stronger solvents - like acetone - we may use for cleaning.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-16-2015, 11:03 AM
PixelWorker PixelWorker is offline
I've always been a fan of the Paasche VL. It comes apart easy for cleaning and is a versatile brush.
Amazon
Old 11-16-2015, 11:09 AM
Thanks, Gil. Yes, it's for primer touch-up, not anything fancy. I saw in the archives a few years ago that you mentioned a Harbor Freight airbrush.
http://www.harborfreight.com/quick-c...kit-93506.html
Does the Badger work better? Since I'm using it for Stewart Systems water-based primer, solvents shouldn't be a problem.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
Old 11-16-2015, 11:14 AM
Amazon
Thanks for the suggestion. I was hoping to find one that's less expensive, since it's just for primer on inside surfaces.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
Old 11-16-2015, 12:42 PM
rvbuilder2002's Avatar
I have been using one of their economy versions for 30 years.
Still works great
Scott McDaniels
Hubbard, Oregon
Old 11-16-2015, 12:49 PM
wirejock's Avatar
wirejock wirejock is offline
Default Paint gun
Thos one works great for small jobs and clean up is easy.
Toss the film container and tube.
http://www.aircraft-tool.com/shop/de...UCT_ID=SA-PP01
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 11-16-2015, 02:32 PM
flyboy1963's Avatar
Default soon to be obsolete??? ;-)
[quote=wirejock;1029982]Thos one works great for small jobs and clean up is easy.
Toss the film container and tube. QUOTE]
...ummm, what's film??
but seriously, looks pretty darn slick!
I found around the shop that the small gravity gun with the fine needle and the air turned way down worked as good or better than my little Paasche or other airbrushes, and so much easier to clean.
http://www.harborfreight.com/20-oz-h...gun-47016.html
I guess if you are working in a tight space, and don't want to spill, you really need a paint cup with a cap at least!
I like the cheap Badger 200 series for all-round versatility, and most hobby stores have parts...they haven't changed the basics in 50+ years!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 11-16-2015, 02:48 PM
az_gila's Avatar
Smile
Ahh... water based
The HF should work - all of the HF problems I had were solvent caused.
For slightly bigger jobs your model shop should sell a 2 oz jar - the Badger one will fit a HF brush IIRC.
Gil Alexander
Old 11-16-2015, 06:08 PM
terrye terrye is offline
Default Primer Pistol
Originally Posted by wirejock View Post
This one works great for small jobs and clean up is easy.
I've had mine for a couple of years and it works OK considering it's price. However, I hope they are doing a better job of soldering the air tube into the hex nut on the front of the gun. Mine separated all by itself and I also managed to break the cheap pot metal hex nut trying to repair it. Luckily I have a lathe and made a new hex nut from brass. If you don't have a lathe, I'd buy two of these "Primer Pistols"
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
