Old 11-13-2015, 05:37 PM
kelleyclark kelleyclark is offline
Smile Team Aerodynamix Nav, Strobe and Landing Lights
I just wanted to share the results of my Team Aerodynamix LED Landing Light, Nav/Strobe installation on my RV-7. I originally purchased a complete lighting system from Van's years ago. After a recommendation from a friend and researching LED lighting systems, I selected Team Aerodynamix's kit. The instructions were easy to follow and the kit provided all needed items. We did have to do some work on the rudder fairing to allow the tail Nav/Strobe assembly to fit. I used two Landing lights (instead of a landing and taxi light) wired with a wig-wag relay provided by Team Aerodynamix. I will be selling my original unused system from Van's in the future.
Hole cut for the the landing light. There is one in each wing wired with a three position switch and a wig-wag relay
Nav/strobe mounting bracket installed in wingtip
LED landing light mounted
LED Nav and Landing Light illuminated
Additional fiberglass added to rudder fairing to accommodate Nav/Strobe assembly
Old 11-13-2015, 06:09 PM
Larco's Avatar
Larco Larco is offline
Yup. needs a redo of the Rudder for a decent fit but it is a nice unit. Larry
Old 11-14-2015, 10:14 PM
Kahuna's Avatar
Kahuna Kahuna is online now
Early model RVs had a tight taper on the rudder fairing for early model nav strobes. Later model LEDs have a larger body for heat dissipation and Vans started making this mount in the rudder fairing larger. I believe this transition in started around 2004.
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
