Old 11-11-2015, 08:37 AM
genelee59 genelee59 is offline
Default ''Perfect" Landings: The Search Continues in my RV-7A
Another unique view of landings from under the plane.
I took in everyone's advice from my last posting of my landings video, and tried to raise the bar (and the nose-wheel too!)
[I polished up the belly even more, I hope Webb notices again ]
http://www.thehdpilot.com/aviation-video.aspx?id=79
TheHDPilot.com
Capturing the Beauty of Flight
VAF Advertiser
Old 11-11-2015, 10:36 AM
Delta Bravo Delta Bravo is offline
Default Nose gear
Just courious judging by the fore and aft oscillations of the nose gear during roll out am I correct that you have not gone with one of the modified nose wheel bearing mods?
Great Video, thanks for sharing.
Old 11-11-2015, 11:01 AM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
I am by no means an expert, and your landings look great. It looks to me that your touchdown speed is a bit too fast. You should be holding it off longer. I remember (long ago) doing a landing and my instructor pulling back on the stick and back up we go. "Too fast" he would bark. You always remember those.
Here's a video I took which I have in another thread about shakey wheelpants with 3 of my landings in it. My video skills are not as good as yours though.
Fast forward to 2:21 for landings.
http://youtu.be/G7rqQa1VIwI
Old 11-11-2015, 06:27 PM
RV7A Flyer's Avatar
No expert here, either, but I concur. 65 kts over the fence and hold that nosewheel off until you run out of elevator authority and it *has* to come down (at a very slow speed).
And...are those flaps fully deployed? They don't appear to be to me, but it might be an illusion because of the wide-angle camera.
Old 11-11-2015, 07:29 PM
What speeds are you guys' wheels coming down?
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Last article: "Gonna Finish This Sucker" (Kitplanes)
Waiting for the avionics kit (backordered: chip shortage)
Old 11-11-2015, 08:33 PM
RV7A Flyer's Avatar
Don't know that I've ever looked, but I can probably tell you exactly by looking at the datalogs from the EFIS (compare airspeed to pitch angle). Stand by...
Old 11-11-2015, 08:36 PM
flightlogic's Avatar
That was a fun video to watch. Nicely edited with voice added in.
Your landings look great by the way. I think all the A model RV's shake a bit when the nose touches... bearing mod or not. It is just really springy.
Keep the stick coming back until it comes down on it's own. You looked good out there !
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 11-11-2015, 09:12 PM
The fork and bearing are vans 2nd gen. The only mod made to that was to drill 2 small holes through the fork into the bearing to stake them with roll pins. It doesn't have the grove or beringer setup if that's what you were asking.
Glad you enjoyed the video!
TheHDPilot.com
VAF Advertiser
Old 11-11-2015, 09:14 PM
RV7A Flyer's Avatar
Well, I thought that would be easy, but the data is pretty noisy for pitch angle, and they're nice small values so it makes it worse, but...looks like it is coming down at around 40 knots indicated or so.
Old 11-11-2015, 09:18 PM
In the beginning, when first learning to fly the plane, I would come down final at 90mph. As I gain experience I brought that speed down to 80mph. I go by MPH rather than KTS because the AS indicator has its larger outer ring in MPH.
That was really an interesting video you made of the shake. Fun to see that someone else did some under-the-wing videoing too. Those wheels Really do shake though, even after the balancing. I couldn't help but go back to my video to see if mine do that too and I'd just never noticed.
-Gene
TheHDPilot.com
VAF Advertiser
