I taped the inlet, put desiccator plugs in the top locations. Others tape a plastic bag with desiccant over the exhaust exit as well when the system is on for good.
I do have to replace/restore the plug desiccate periodically Just be sure you read about how long it takes. You can get the color indicator to change quickly, but all the water is not removed for a much longer time at temperature.
Bill
RV-7
Lord Kelvin:
