11-09-2015, 04:43 PM
Engine smoothness question ?
RV-3 with 0320parrallel mount w/carb,dual Pmag and Catto 2 blade 😞
Would a dynamical 3 blade be worth the effort to upgrade ?????
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
11-09-2015, 04:45 PM
Super Moderator
Oh yes!
I just balanced my MT 3 blade down to .02 IPS.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
11-09-2015, 05:04 PM
I think he?s asking if it would be worth upgrading from 2 blade to 3 blade. I don?t know what a ?dynamical 3 blade? is.
2 blades or 3, they both work well, if you like your 2 blade I would keep it, if you want a 3 blade get a 3 blade.
11-09-2015, 05:14 PM
Super Moderator
Sorry
Missed that. But yes, my experience has been that the 3 blades can be a little smoother. Not to start a war. I said CAN be.
 Vic Syracuse
11-09-2015, 05:19 PM
Mount significance ?
OK, Craig says a 3 blade might be smoother, and of course, balancing can only be worth 0 to plus X? My real unknown is the value of dynafocal. That would require a new mount, new engine and probably a cowl.
Larry DeCamp
Clinton, IN
11-09-2015, 06:35 PM
There is a conical mount upgrade that works better than the standard Lycoming part.
It is Lord mount part J1552. About 5 times the price, but they do make a difference.
11-09-2015, 06:48 PM
Must be something like a "jellicle" cat
Yeah I know that a 3 blade prop is smoother and lots more sexy looking than a 2 blade, but a 2 blade is slightly more efficient than a 3 blade and a whole lot cheaper to buy.
Neal Howard
Airplaneless once again...
11-09-2015, 08:25 PM
A dynamic prop balance is a lot cheaper than a new prop and has, on mine, made a big difference and that's with a 2-bladed prop. Of course if the dynamic balance wasn't enough and then you got that new prop afterwards, that would be money wasted, I think.
How is the mixture? Any smoothing when you lean or enrichen it?
Dave
11-10-2015, 08:58 AM
Larry, the only other thing I wondered about, given the snug RV-3 cowl, is whether the engine is bumping into something.
Dave
11-10-2015, 10:17 AM
VAF Moderator / Line Boy
Ownign both two and three-blade props, I know that they can both be made as smooth as silk with a good dynamic balance. You have several unknowns that, unless you throw money at them, you really don't know how they affect the overall result. Going Dynafocal should help, but it would be a big deal to change. A new prop? Always fun, but unless you have other reasons to change the prop, I think I'd go for a dynamic balance first, and see if that helps.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
