I would try another sender or a direct mechanical gauge to compare. Mine reads 27 lbs normally. This is a Lyc 360 with Silverhawk injection and Vans (Airflow performance) boost pump.
When pumps fail, they would perform less "work" (pressure/flow), not more. Not always the case with senders.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
