Old 11-05-2015, 11:35 AM
Steve51B's Avatar
Steve51B Steve51B is offline
Originally Posted by jdearborn View Post
Troll the guy. If he had missiles you'd already be toast or he's just a 'gunner'. Max power and turn into him with just enough 'G' to prevent a firing solution. Trade off some altitude to maintain your energy. He'll think you haven't seen him. If he dissipates energy (slows down) to saddle up for the shot, you can then apply the rest of your available 'G' to force an overshoot. Now it's your turn!! If he keeps his energy and pitches up (high yo-yo) it may be time to 'bugout' while he is nose high. A high wing (C-180) vs low wing (Mooney) in a turning fight is not a good idea. Always watch out for dash 2!
****This all is assuming his aircraft has a performance advantage.
I'll second that. Chief Pilot may actually have seen that before... Not sure, Hmmm...
Old 11-05-2015, 11:39 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Could be. Happens now and again when I'm flying around in the QRV-6A...
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 11-05-2015, 12:00 PM
Flying again!'s Avatar
Flying again! Flying again! is offline
Default Need to Turn the Transponder on
Originally Posted by David-aviator View Post
I fly locally a lot and never see another airplane - yesterday had 2 close encountered. One guy a Mooney, appeared to have jumped me from 5 o'clock, I broke the other way in a 180 and he kept on going. The others was a Cherokee minding his own business.
I hate to spend more money on this airplane but it looks like ADS-B is a coming necessity. I don't like in flight surprises.
The problem is that for ADS-B to work the other guy has to have a transponder installed and ON. I fly under the DFW Class B shelf (obviously within the Mode C veil) where use of a transponder is mandatory. I am surprised how many planes I see that are not showing up on the ADS-B in (such as the traffic patterns at local airports).
Please, please if you have a transponder, turn it on every time you fly, even where it is not "required".
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
Old 11-05-2015, 12:04 PM
Stitch462's Avatar
Stitch462 Stitch462 is offline
Originally Posted by ChiefPilot View Post
I don't think ADS-B will help.
If a Mooney is jumping you from five o'clock, then that implies he already has a serious energy advantage. If he was set up for a close-in flight path overshoot, a break turn may temporarily neutralize his attack but he will still have a net energy advantage while you've just used more of your energy in the turn.
One option might be a lag/displacement roll to your left. This will force the Mooney to overshoot while preserving your energy state and putting you in an offensive position. Depending on his experience, the Mooney driver will likely extend and disengage. Be prepared for a rolling scissors however if the Mooney driver possesses the spirit of attack.
Not sure how ADS-B is of any help in this scenario.
But if he [the RV driver] went into a right cross he could immediately go to guns on him. Oh wait, maybe that's too aggressive...
Stitch
MSgt, USAF, Ret.
RV-8 Dreamer
Steve51B's Avatar
I'm in a hangar with 3 other planes near the interior rings of a Class B area. I'm the only plane in that hangar that has an electrical system and is required to have a transponder. Of course it's on all the time, but those other guys don't even have them. Best not rely on anything but keeping a good lookout. I fly planes with TCAS at work and they are great, but we never completely trust it. Every once in a while we have one of those moments... "where did that guy come from?"
Old 11-05-2015, 12:08 PM
Bevan Bevan is offline
Default Radar
You may have had a heads up had you been operating your rear facing Synthetic Aperature Radar (SAR) system. A quick internet search turned this up. Just scale it up.
http://www.popsci.com/diy/article/20...dar-system-250
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 11-05-2015, 01:17 PM
esco esco is offline
Default GIB?
I thought it was the backseater's job to look out for traffic from the rear.
While this is a side-by-side, it illustrates the concept.
______
VAF dues paid though exempt
RV-9A sold (I miss that bird!)
RV10 sold (miss that one too!)
RV-14A build underway
Old 11-05-2015, 01:19 PM
scsmith scsmith is offline
Well, in fact, if you have one installed, it is "required" that it be turned on, even where it is not "required", except in the fairly rare case of Class G airspace. See 91.215(c)
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 11-05-2015, 01:22 PM
If a Mooney is jumping you ...
Wouldn't the ADS-B be an asset for keeping track of where the Mooney is?
One thing I've never quite grasped is how you can keep sight on the opponent as both aircraft maneuver after a neutral break.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
Old 11-05-2015, 01:28 PM
Especially at jet speeds and low vis paint schemes. Very sore necks the next day.
Bevan
Dual P-mags
Grand Rapids EFIS
