Old 11-04-2015, 09:53 PM
Noah's Avatar
Noah Noah is offline
Default PP Alternator - Mount Hole Elongation
Took off my 60A Plane Power Alternator to inspect the brushes since I've gone over 500 hrs in the past year. Plenty of meat left on the brushes but I found this:
Anybody seen this sort of elongated mounting hole? This is the upper bolt hole which swivels to allow belt to be tensioned by tightening lower bolt. Not sure of the cause, I have checked and adjusted belt tension at every annual, bearings are good, haven't had any problems with this alternator.
How about a repair? I was thinking of boring oversize and making a bronze bushing. Or is there a better way?
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 11-05-2015, 06:19 AM
RVDan RVDan is offline
I have seen this before. It happens when the through bolt isn't tightened, which needs to be done after you adjust the belt tension.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 11-05-2015, 06:29 AM
BillL BillL is offline
I would agree to the cause - if it has good area contact on both sides, I would just tighten it back up good and check on oil changes. If tight, it won't be moving anyway, the sides keep it aligned. No harm.
Funny it has lasted so long, maybe being loose allowed it to live longer?? I wonder? . . . .. nah.
If it really bothers you, machine out the hole on original center and make a new bushing from steel.
Bill
RV-7
Lord Kelvin:
