Originally Posted by LettersFromFlyoverCountry
it would be cool if the VP-50 had been designed to say "hey,you turned something on and it's not drawing any juice".
Bob,
That feature IS in the VP-50 - it is called current fault alert. You have to enable it for each circuit which you can do in setup.
Also, you can read the current of each circuit, and that is accessible any time form the main screen (it is not in setup).
Those two things should help you troubleshoot the problem. VP-50 manuals are still up on the web site.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser -
Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
