Old 10-31-2015, 01:35 PM
sbalmos's Avatar
sbalmos sbalmos is offline
Default Nutplate interference with engine mount
I'm not worried. Just scratching my head. I have a conical engine mount, and the four corner bolt holes are fine (just darn tight). But before I drill the two lower inboard holes, I noticed that one of the nutplates for the red cube seems to be interfering with the lower cross-tube of the engine mount. I've read elsewhere about how you normally have to shim these two inboard holes. But this seems different. This interference is also pulling forward the lower left corner bolt hole, which makes that bolt darn near impossible to full fit through.
At worst, I'll remove the nutplate. I'm not using a red cube - the EFII system has a converter sensor of its own. I'll probably just patch over the firewall hole with a steel plate or something. This seem okay, or should I be considering other avenues?
Scott Balmos - RV-9A N112SB
Cincinnati, OH, KHAO
Old 10-31-2015, 01:44 PM
Bruce's Avatar
Bruce Bruce is offline
Scott,
I would remove nut plate and fill with rivet and bolt or
Stainless steel pop rivets.
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
Old 10-31-2015, 02:18 PM
Pat Stewart Pat Stewart is offline
Must remove the nut plate.
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
Old 10-31-2015, 02:20 PM
sbalmos's Avatar
Okay, okay... Done!
