  #11
Old 10-30-2015, 11:11 AM
RV7ator RV7ator is offline
Default Hartzell v. 74RV
I changed from a 72" Hartzell BA to a 74RV at 75 hours on a IO-375 mounted on a -7. I was concerned about vibration effects on an aluminum club from a ~210hp engine with EI, 9.6:1 compression. What performance comparisons I made did not show detectable, repeatable results between the two. My butt tells me the 74RV is a bit smoother. Prop looks a lot faster than what you'll experience. Don't sweat the inch radius on a TD unless you try to "pin" a botched wheelie. I know a guy who trimmed a BA from 72 to 70 doing this.
John Siebold
Old 10-30-2015, 03:11 PM
DAS DAS is offline
thx all,
John, is there any sig problem with the 210 hp in the RV7? I was looking at superior's engine, similar hp....obviously vans "can't endorse that HP, but you're the builder, so you can decide" was their answer..
das
Old 10-31-2015, 09:22 AM
More horsepower = better. Too much horsepower = best. You can always pull back the black knob.
Now let's see where this thread drifts.
John Siebold
Old 10-31-2015, 09:41 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default 200 HP +
I had a 200RV on the 7 that I sold and it was great. Smooth and reliable. The new 7 will have a new IO390 with Barrett Precision work done. It is close to 220 HP.
I consulted with Whirlwind and they said the 74 is most efficient with 200+ HP engines. Below that the 200RV is more effective. The 74 has more diameter and a thinner blade.
So, 200 or less go with the 200RV, 200+ consider the 74.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
