Old 10-21-2015, 04:44 AM
Jstov Jstov is offline
Default Dresser retreads
Does anyone use the monster retreads on their -8 and do you know if they will still fit the pressure recovery wheel pants? Looking to get longer time on the wheels! Thanks
Old 10-21-2015, 05:36 AM
Scott Hersha Scott Hersha is online now
I just put on a set of Monster retreads on my -8 (second time). They fit fine. The carcass on mine are Michelin 6-ply.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 10-21-2015, 05:53 AM
Paul K Paul K is offline
Lots of recent post about this subject but to recap, yes they are generally liked and yes they fit the wheel pants but you will have to make the opening in the bottom a little larger.
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
Old 10-21-2015, 05:59 AM
Default Thanks
Thanks guys I used the search feature but I only checked the 8 pages and did not find much there.
Justin
Old 10-21-2015, 07:01 AM
n816kc n816kc is offline
Default Elite Retread
I use the Desser Elite Retread. It's a little bit smaller than the Monster and fits my wheelpants much better (still had to trim a little moving up from the kit tires). Last set lasted 350 hours, almost exclusively off pavement. Highly recommend.
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2019 =VAF= donor
Old 10-21-2015, 09:16 PM
Doug's Avatar
Doug Doug is offline
Depends also on how low the wheel pants were fitted to the wheels.
I set mine according to the plans with a 1" gap between the Aero Trainer tyre tops and the wheel pant and I'm pretty sure there is insufficient clearance to fit a thicker retreads on Michelin or other larger diameter case.
Doug Gray
RV-6 completed, flying since July 2010
Old 10-22-2015, 07:01 AM
g zero g zero is offline
Default Retreads
I put Goodyear Flight customs on my 8 . Trimmed the wheel pant 1/2" around the sides and about 3/4" around the front and rear . 100 landings on pavement and the tires show almost no wear . The advantage of using new vs retread is consistent tire dimensions .
A new set of Goodyears aren't a whole lot more money than recaps , and how old and what has the tire they recapped been thru .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 10-22-2015, 04:50 PM
My wheel pants are painted and perfect so I think I will just go with the new tires. I would rather fly than grind glass I have done that enough! Thanks for the replies!
