Old 04-21-2005, 10:08 PM
Ted Farmin Ted Farmin is offline
Default Fresh air vents location RV4
Would like to know where the best location for fresh air vents on the 4.
I am thinking about installing them on the canopy skirts, would appreciate
input from experienced users.
Ted
Old 04-21-2005, 10:50 PM
szicree szicree is offline
Don't start cuttin' yet! I've not done mine yet, but I have heard that the skirts do not work well without v.g.'s. Hopefully we'll both get some good advice on the subject.
Steve Zicree
RV4 Finishing (yeah right!)
Old 04-22-2005, 05:49 PM
Joe Hine Joe Hine is offline
Default RV4 Fresh air vents
Ted
Hi Ted
The wisdom from those who have tried the canopy skirts is that they don't work very well there. I put one flush vent in the side, just below the cowl cheek extention and ran a two inch scat tube to a eyeball vent on the panel. Works very well. Even the prop blast on a hot day gets some air moving in the cockpit. I only have the one, but in flight if I adjust just right, I get half the blast on my face, and the rest hits the backseater in the face. Others have put them under the wings. Outboard a bit to make sure you avoid exhaust and run the scat tube to vents where ever you want. I think this would work better for back seat vent. The one on the side works well for the front.
Joe Hine
C-FYTQ
Old 04-23-2005, 06:53 AM
Skyhook Skyhook is offline
".. I put one flush vent in the side, just below the cowl cheek extention and ran a two inch scat tube to a eyeball vent on the panel."
Mine is located in the same place described above, on the starboard side, and the amount of air is impressive.
Old 04-23-2005, 02:41 PM
svanarts svanarts is offline
I used NACA scoopes mounted just below the cheek fairings. They run to vents on the extreme lower ends of my instrument panel. Very good airflow here.
I've also heard that people have had good experiences puting NACA scoops under each wing and then routing the scat tube into cockpit. Extremely good airflow.
Scott VanArtsdalen
www.airprayer.net
Old 04-23-2005, 04:03 PM
Scott,
I assume you have a vent in the lower corners of the panel. Is it adequate for the back seater, or do you think I need something routed to the rear?
Steve Zicree
Old 04-23-2005, 11:58 PM
Mustang Mustang is offline
Yeah,
For sure don't bother installing a scoop on the side of the canopy fairing. I flew my friends "4" yesterday for a couple of hours and I just baked in the clear skies. After every flight I got out of the cockpit totally drenched. I opened up the little NACA scoop right next to my face and it was like baby's breath on my cheek????
Cheers, Pete
Old 04-24-2005, 09:26 PM
Marc DeGirolamo's Avatar
Marc DeGirolamo Marc DeGirolamo is offline
Default canopy vents
I have two NACA vents....one on the starboard side below the cheek cowl and ahead of the leading edge (for front seat), and one on the bottom of the starboard wing second bay aft of the front spar (for rear seat). They both will blow your hat off....
Marc DeGirolamo
Canadian..Rv-4 Flying
VAF # 144
Old 04-24-2005, 10:01 PM
Default Vents
Thanks Marc, that is the info I was looking for.
Ted
Old 04-25-2005, 07:32 PM
Originally Posted by szicree
Scott,
Steve Zicree
My wife told me to close them a couple of weeks ago in flight because she was too cold. She could feel the breeze just fine. Now mind you, she's always cold so your mileage may vary.
Scott VanArtsdalen
www.airprayer.net
