Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
01-16-2016, 08:10 PM
paint is not ready for tape until 36 hrs. even though the book says 8 hrs I was not comfortable with it because at 12 hrs it would leave a mark that would gradually fade away after the tape was removed. no damage done. walk away.
question about N number... I planed on painting a background N number blue over the existing white (number to be white) but I am not sure if I can dig this paint mask out and get clean lines with urethane. anyone have any experience with this? my other option is to paint the blue and them come back and paint the white N number over the blue. I still have two unused masks remaining.
my wife came over to inspect the curve. she was happy with it. you know, I was nervous before painting the fuse overall white, she called me on the phone at the hangar and said not to worry about orange peel because like a golf ball it will make the plane go faster. that is TRUE LOVE!
laying stripes on an airplane is fun. nothing fancy here. I can imagine folks doing fancy paint jobs enjoying their work.
01-16-2016, 08:34 PM
cowling paint line. I do not think where the line is matters, I was only going for symmetry.
I pulled a tape line for the bottom blue across the lower cowl for each side half way and met close to the middle. I picked the one I liked best and made a template and duplicated the other side. mark the template with a pencil and cut the line. the trick is to find the cowl center with the template. the trial and error method worked for me on the 5th measurement. very little wasted tape with this method. this 1/4 inch tape in the picture is the negative. I latter swept a 1/2 inch blue tape around the entire cowl as one piece to match the 1/4 inch one. the wider tape gave a smoother line and was still able to contour.
01-17-2016, 07:20 PM
01-18-2016, 07:30 PM
01-18-2016, 07:34 PM
on to the tan stripe, two medium coats. outside air temp = -11C, paint temp = 76F, booth temp on first coat 75F, second coat 62F. DT885 reducer. the paint was supposed to match the interior but is glossy and seems to appear lighter color, maybe when it dries it will be darker. one more burgundy stripe to go and then I will be done with the fuse. stripes are easy, just pull the trigger and walk.
also, I am scuffing the painted color areas with grey (very fine) scotch-brite pads. the white paint is four days old and still soft. I tried both the grey and the red (fine) pads. the red pad seemed to be too rough. with the grey pad I noticed I could see scratches from the pad in the first coat of tan paint from the pad but not the second coat.
baking at 65F
01-20-2016, 04:16 PM
01-20-2016, 04:21 PM
01-22-2016, 08:55 PM
wing booth
01-22-2016, 09:56 PM
Originally Posted by fixnflyguy
Steve,
I painted my -4 DIY as you are. I am in the aircraft business, and have painted several cars, so I may have a slight edge, but I'm no pro. I used PPG epoxy primer, DP40, which is a very easy to use primer, can be sanded if needed, and is compatable with Aluminum,Steel, and Glass. It is easy to find at auto supply stores. I did my topcoat with PPG Desothane, which is widely used by the airlines for the big boys. It is a single stage urethane and works very well, and can be cut and buffed if needed. In lieu of the PVC booth, I built a 24'x24' frame of 2x4's , 8' tall, and suspended the center of the 4 cross pieces with rope from my hangar ceiling so it was open span. I left the front open with 4' spacing on vertical pieces for the other 3 sides. I made a "roll up" door with a PVC tube at the bottom so I could move the plane in and out. This was also a great place to work in winter, and it heated with a kero heater a lot better than the whole hangar. I taped in place 10 heater filters at the top of the roll up door, and put 3 exhaust fans at the back lower edge of the enclosure which I vented out of the hangar.The booth took a weekend to build, and worked great. I have less than a grand in my paint job, and 7 yrs. later it still looks perfect (except the couple party fouls I know of). Yours is coming along great, and you will be proud to say you did it yourself!
this guy gives another approach which is good. the trouble was I could not fit a bigger booth in my hangar, but if I could have I would have. I would need more lights with a bigger booth.
01-24-2016, 07:39 PM
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
