0 320
I have an 0 320 with 10-1 pistons, balanced, no other mods. Bendix mags and stock Marvel carb. I have a Sterba 70 x 82 prop that was intended for a 0 360 RV4. It is way too much prop. Full throttle at 4500' I am only turning about 2500 r/m. The airplane is not an RV. I am truing about 205 statute at 2500 so the airplane is pretty clean aerodynamically.
The carb is just slightly on the lean side at low altitude.
I estimate the horsepower is only around 150 at 2500 r/m.
I need a prop that will turn at least 2700 full throttle at altitude and maybe even 28-2900.
The best you can expect from an 0 320 is 170-175 hp, unless you want to go above 10-1 compression.
