Like Pat said. sometimes jacks can not make contact and sometimes grounds come undone.
Pins generally if installed correctly will not work out if they had been working properly. But if you have the radio in and out you increase the case of a bent pin .
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
