Old 10-15-2015, 09:15 PM
AviatorJ AviatorJ is offline
Default Fixing a dimple/countersink mistake
Bit of a technique question here. While doing some assembly of my elevators I noticed I countersinked the wrong side of the aft spar (9-8 step 2). So now instead of the top having a smooth surface for the trim tab hinge it's dimpled, and the bottom is smooth. This is only on the left elevator, did the right one correct.
I can't think of any issues of the bottom part having countersinked vs dimples, but I obviously need to fix the top for it to be smooth. One option is to flatten the dimples with a squeezer and then countersink. The other is to grind the back side of the dimples flat. My concern with flattening is will it weaken the metal? Then my concern with grinding is it will remove material and possibly make the hole larger.
Either way the goal is to have a flat surface to attach the hinge.
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
Old 10-15-2015, 09:29 PM
This is the spar?? I'd throw it in the trash. But, run your proposal by Vans and see what they say.
Old 10-16-2015, 03:48 AM
RV10Man RV10Man is offline
PM sent. I live in Oklahoma City
Old 10-16-2015, 06:21 AM
Replied back to you.
Will call Vans in a few hours and take whatever corrective action they see fit.
Justin
RV-10, N10JW
Old 10-16-2015, 08:39 AM
Talked to Vans this morning and will be replacing the part. The general thought I got from the conversation was that if it's easy to replace, just do that and make it right so you never have to worry about it.
There's no hard line rule though on flattening a dimple to countersink... he did say he didn't like to do it on thick metal, but it can be viewed on a case by case basis.
I also figured out what I did... I followed the same picture on both and made two right hand elevator parts...
Justin
RV-10, N10JW
