Old 11-29-2006, 06:41 PM
flybynight55 flybynight55 is offline
Default Which dynofocal mount do i have??
I just purchased an RV4 with a dynofocal mount. Its my understanding there are 2 types. How do I tell which type is on my plane? Will an engine that fits one type also fit the other type?? Does it matter?? Thanks, Tom in Ga.
Old 11-29-2006, 06:46 PM
Mel's Avatar
Mel Mel is offline
To my knowledge there is only one conical mount. There are 2 dynafocla mounts, type 1 and type 2. The type 2 is for the IO-320 from the Twin Commanche. The type 2 has a shallower angle because with the long prop extension of the Commanche, the cg of the engine is farther forward.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-29-2006, 08:22 PM
Default Thanks Mel, stupid me
Thanks for reply. I meant to write Dynafocal, but mistakedly wrote conical. Sorry to you guys. But still, how can I determine which one i have if I don't have both kinds in front of me to gage from?? I assume this mount came with the plane originally, but you know when you buy something used, you never know whats been changed. Thanks again to all that have answered all my questions here. Tom
Old 11-30-2006, 06:37 AM
rvpilot's Avatar
rvpilot rvpilot is offline
Default Dynafocal mounts
Check out this link-
http://vansaircraft.com/pdf/engine_id_form.pdf
This is the engine ID form from Van's, also has a picture showing the difference in the angles between the two mounts. Might help you fiqure out which one you have!
Good Luck!
Bill Waters
Based KCVC (Covington, GA)
RV6A - Gone, but not forgotten!
RV8 - Gone too, now winning races in the RV Gold Class!
RV4 - Flying!!!
Old 11-30-2006, 10:13 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Engine #
Is there a data plate on the engine? You can tell by looking, chance is its a Dynafocal I, more common. IF you have a data plate you can look up.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
