The bolts are torqued against a rigid spacer in between the rubber isolators, so it's unlikely that they will need a retorque unless there was excessive paint between the mounting surfaces.
There are inspection limits on the LORD website which provides acceptable/not acceptable sag.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
