Go Back   VAF Forums > Avionics / Interiors / Fiberglass > COMM
Old 10-10-2015, 07:22 PM
Apexeon Apexeon is offline
Smile Need help with weak audio on passenger side (Problem Solved)
I have a KX-125 nav/com and a PS intercom in my -6. Everything sounds fine on the pilot side. Radio transmission/reception and intercom are both loud and clear. However, on the passenger side the intercom transmission/reception is fine but the radio reception is about 30% as loud as on the pilot side. I can't understand why there would be reduction in the output on the radio but not on the intercom. Would appreciate any ideas on where to start.
Don Thompson
Tallahassee, FL
Hangar D-3 Quincy, FL (2J9)
N726DT RV 6 Flying
N4493J '67 Cherokee 140 sold
N2120J '78 Warrior II owned twice, sold twice
2017 Dues Paid
Old 10-11-2015, 10:11 AM
Flyingleap Flyingleap is offline
Default Volume issue
Start, check the headphone volume control....just sayin...
Also, need more details of your system. Isolated ground on headphone jack?
John
John R Prince
RV-7 want-a-b
Dues Paid for 20
Old 10-11-2015, 12:03 PM
Sam Buchanan's Avatar
been here awhile
Interested in any replies, I have the same combination of devices...and the same problem.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 10-11-2015, 07:37 PM
John
John I tested by tuning the ATIS and switching the headphone from pilot jack to passenger jack. I have also had passengers who could hear intercom fine but could hardly hear radio reception. Both the phone jacks are ground isolated from the aircraft frame.
Don
Don Thompson
Tallahassee, FL
N726DT RV 6 Flying
2017 Dues Paid
Old 10-12-2015, 07:36 AM
Default Volume problem?
Don,
Pin 2 of the Kx125 is your audio out with pin 6 being the comm audio lo. This might be the problem if wired wrong. Aircraft ground (AC) is pins 4,5.
Also, disconnect the headphone jack and plug in the headphone to see if the audio changes volume. These are just troubleshooting tests, but lets see.
I have a manual on the KX125, but don't know the audio panel/amp you are using.
John
John R Prince
RV-7 want-a-b
Dues Paid for 20
Old 10-12-2015, 07:41 AM
Default Connections!
Let me read the manual a little more.........The Kx125 does have some wiring quirks....
John
John R Prince
RV-7 want-a-b
Dues Paid for 20
Old 10-12-2015, 01:45 PM
RV7A Flyer's Avatar
I have a *different* combination and the same problem reported by passengers (I have a GMA340), but frankly, I've never been able to replicate it through any combination of switching headphones and such while on the ground.
I suspect that's it's the combination of too many variables that sometimes results in a set of bad settings...there is headphone volume (Bose A20s or Bose Xs), comm radio volume, and intercom volume.
Old 10-12-2015, 02:30 PM
Default Here's one possible check!
I did find in the manual of the KX125 regarding a loss in audio and the microphone on the passengers side. So, unplug mike on passenger side
and see if audio comes back to that side. Yes, this sounds odd...
There are so many notes on this install.....
John
John R Prince
RV-7 want-a-b
Dues Paid for 20
Old 10-12-2015, 06:56 PM
John
Thanks John, I will give that a try next time I get out to the airport.
Don
Don Thompson
Tallahassee, FL
N726DT RV 6 Flying
2017 Dues Paid
Old 10-13-2015, 02:56 PM
Doug's Avatar
Doug Doug is offline
If you swap headsets does the problem follow?
Does the problem remain with the intercom power switched off? On my PS intercom turning the LH knob fully CCW the intercom is switched off and the connection is direct between the radio output and headset.
My thinking is that the headset impedance may be different between the headsets which will affect the relative audio level if the radio's output impedance is high. Also, check both headsets are set to Mono (or Stereo if that is how it should be).
Doug Gray
RV-6 completed, flying since July 2010
