Old 03-09-2016, 03:24 PM
Driving '67 Driving '67 is offline
Hi Scott,
I've bumped into the same issue today. Has there been a solution?
Thanks Jim
RV 14A
Serial 140118
Donation - 2020 gladly done!
Old 03-09-2016, 08:05 PM
rvbuilder2002's Avatar
Originally Posted by Driving '67 View Post
Hi Scott,
Thanks Jim
What is the revision level of the drawing(s) you are using?
Scott McDaniels
Hubbard, Oregon
Old 03-09-2016, 08:31 PM
Hi Scott,
Not a big deal, just curious. Working off of Rev 1. The distance from the top of the hinge to the pilot hole causes a mis-alignment as mentioned by KeithB. I basically did the same as him for alignment. Hopefully this will work come "cowl" install time.
Jim
RV 14A
Serial 140118
Old 03-10-2016, 09:14 AM
mike newall's Avatar
mike newall mike newall is offline
One solution is Skybolt camlocs.......
Just a thought
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 03-11-2016, 07:47 PM
Hi Scott,
I see the distance has been amended in the plans revision published today.
Thanks Jim
RV 14A
Serial 140118
