Old 10-08-2015, 01:51 PM
SgtZim SgtZim is offline
Default New guy wondering why?
I'm planning how to run wires and hoses through the wing, and seeing the "recommended" method and seemingly universally used of cutting holes in all of the ribs to run a conduit to the wingtip. I see lots of really big holes already in the ribs and wondering why we don't have (or maybe there is) a neat way to clamp that conduit to the edge of the lightening holes - leaving my ribs very slightly stronger???
Comments? Appreciated!
Old 10-08-2015, 01:55 PM
rmartingt's Avatar
Talking
Weight savings (removed material plus hardware not needed)
RV-7ER - finishing kit and systems installation
Mel's Avatar
Mel Mel is offline
That IS done and it is not uncommon. Just be sure that if you use the same holes that pushrods run through, you manipulate the controls to all possible configurations, making sure to provide plenty of clearance.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-08-2015, 02:08 PM
DaleB's Avatar
DaleB DaleB is offline
I used fluorescent lamp sleeve tubes run trough the lightening holes in the ribs. Very thin wall polycarbonate, lots of room for wire and they weigh almost nothing. They're secured with tabs and zip ties, with a dab of RTV on each tab just for good measure.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 10-08-2015, 02:42 PM
RV7A Flyer's Avatar
There are a lot of nice solutions for holding wire bundles or conduit in place and protected at the edges of lightening holes...
Things like this:
http://www.panduit.com/wcs/Satellite...ame=PG_Wrapper
Old 10-08-2015, 03:01 PM
Auburntsts's Avatar
Simplicity is why I went Van's corrugated tubing. Drill a 3/4 inch hole, thread the tubing through and done -- no fasteners required and t he install is quick and easy.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 10-08-2015, 03:18 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Same for me. Easy peasy, very little weight, and follow's the Mother Ship's recommendations.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 10-08-2015, 03:54 PM
sblack sblack is offline
The web really isn't doing much in terms of strength. That's why you can cut a 5" hole in it and not impact wing strength. So another 3/4" hole makes no difference. It is basically there to hold the 2 rib flanges apart. Think of a built up wood rib - there is nothing in the middle for 95% of it - just a few sticks. If you want to do it your way then great - your airplane. But if you run a conduit don't worry about strength. It is not an issue.
Scott Black
VAF dues 2020
Instagram @sblack2154
