Old 10-05-2015, 01:54 PM
YellowJacket RV9 YellowJacket RV9 is offline
Default Van's crossover heat muff question
I am working on fitting my exhaust system, it is the one from Vans, along with their newer crossover heat muff. Out of the box, the openings in the heat muff at either end will not quite fit around the enlarged flanges at the slip joints. Is this just supposed to be a very tight fit, do I need to slightly enlarge the openings, or do I have something wrong? The instructions that I found (https://www.vansaircraft.com/pdf/rev...ther/OP-54.pdf) don't make any mention, other than to say the slip joints must be outside the box. I did measure the openings and found that ones that accommodate the slip joints are 1/16" bigger, but still not quite big enough. Here is a picture of how things look for me:
Any ideas? Thanks!
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 10-05-2015, 02:51 PM
Hey Chris,
I've got the same heat muff, and I had to do a little Dremel work to enlarge the cutouts. The holes should be centered on the fat parts of the slip joints.
Fortunately, you don't have to remove too much material.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 10-05-2015, 03:02 PM
rvbuilder2002's Avatar
The intent is for a tight net fit.
It is not intended that you would have to enlarge the holes as Doug did, but since the tube expanding process is not high precision, I can see some of them being a bit tight occasionally.
It should only require removing a few thousandths with a sanding drum.
Scott McDaniels
Hubbard, Oregon
Old 10-05-2015, 03:23 PM
Just what I needed to hear/see. Thanks to both of you
Chris
Chris Johnson
Old 10-05-2015, 03:25 PM
MarkW's Avatar
MarkW MarkW is offline
Mine did not require enlarging. Fit tight right out of the box.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 10-05-2015, 06:38 PM
N941WR's Avatar
N941WR N941WR is offline
Is that crossover heat muff the new "standard" muff?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-05-2015, 06:52 PM
I believe they still carry the old style, but this is what is included in their exhaust kit. Some other threads on here indicate that it is supposed to be more effective, and people have been pleased with it.
Chris
Chris Johnson
Old 10-05-2015, 07:33 PM
N941WR's Avatar
Chris
Thanks! I was just curious.
Bill R.
SC86 - Easley, SC
Old 10-05-2015, 09:31 PM
It is the heat muff included with the exhaust system for the parallel valve O-320/O-360 that is manufactured by Van's
Scott McDaniels
Hubbard, Oregon
Old 10-06-2015, 10:32 AM
Closterman's Avatar
Closterman Closterman is offline
Default Scat tube from heater to firewall
I'm curious about how you will route your tube from the heat muff and the firewall. I right here and I can't figure where I will route this tube. I don't want to interfer with my throttle cable, the exhaust and the cowl... If someone have a pics of that... Thanks
Martin "Closterman" Rousseau
www.mraerodesign.com
Piper Cherokee C-FEYI (sold)
RV-7A C-GMYL Status : FLYING with perpetual RV Grin!!!
RV-9A Status : Tail & Wing 90% Fuselage: 10%
Hatz Classic : building wings (on hold)
http://www.mykitlog.com/Closterman/
Donated to VAF (12-2017)
