There's lots to owning an experimental, lots more than owning a certificated aircraft. It's not just the flying, it's also the maintenance. The saying, a half-truth, is that "It's an experimental and you can do what you want." The rest of the statement is that there may be unforseeable and severe consequences.
I've own(ed) RV-4, -8, -8A, and -9A. All of them were well-recommended before purchase. If I were to give them letter grades, though, they'd get A+, A, C, and D. Some of the deficiencies would not have shown up on a detailed pre-buy inspection, but only on disassembly.
Homebuilts are not for the uninformed or the passionless, end even for the conscientious and careful, there can be surprises.
The -8A fishtails a little in turbulence, and although you might not notice it up front, I've had a CFII buddy in the back want to call it quits after less than an hour because of queasiness. And although the back seat of an -8A is roomy enough, there's not much wiggle room.
Send me your phone number and we can talk.
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
