Old 10-02-2015, 03:25 PM
ArlingtonRV ArlingtonRV is online now
Default Bus Voltage
This should be a simple answer, but I am having a great deal of difficulty in finding it.
I am trying to find out what "normal" bus voltage should be in a 12 volt system that is functioning properly. The reason that I ask is that I have a Dynon Skyview and with the engine running (alternator supplying power to the bus) it reads 14.4 volts and shows in the yellow range. It is easy enough to change the color coding of the "gauges" in the Skyview so that it isn't yellow, but before doing that I though I should find what "normal" is.
Do I need to worry about 14.4 volts? Is that good, bad, or indifferent? If it is not good, is there any way to adjust it?
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
RV-8 (Bought Flying)
Glasair Sportsman (Sold)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 10-02-2015, 05:08 PM
terrye terrye is offline
Default 14.4 volts
14.4 volts is a good number for an alternator supplied 12 volt system. That's what my C-150 has always read since I put a voltmeter in the panel. That's also what you get if you check an automobile system when the engine is running. The reason it's called a "12 volt" system is that's what the battery voltage is.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 10-02-2015, 05:49 PM
Mich48041 Mich48041 is offline
Yes, 14.4 is OK. Many voltage regulators are set at 14.2
The ideal voltage depends on battery temperature. But I think that anything between 14 and 14.5 is OK.
Joe Gores
RV-12 Flying
Old 10-03-2015, 12:46 AM
f14av8r's Avatar
f14av8r f14av8r is offline
Default AGM Charging Voltage
My AGM battery, an Odyssey PC680, manual says it requires 14.1 to 14.7 volts for proper charging. Other sources I've read say the high end is better. So, I have my B&C regulator set for 14.7 volts and my Vertical Power/SkyView/PC680 system very happy.
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through March 2021
Old 10-03-2015, 05:19 AM
larrynew's Avatar
larrynew larrynew is online now
Originally Posted by f14av8r View Post
my Vertical Power/SkyView/PC680 system is very happy.
+1 at 14.4 volts.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 10-03-2015, 05:53 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Modify your Skyiew settings to bump the yellow lowew limit up a couple of tenths. It gets rid of the pesky warning when everything is really operating normally.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 10-03-2015, 03:41 PM
gasman gasman is offline
I set High side 14.5 yellow, 15 red. Low side 13.5 yellow and 12.8 red. The upper end is covered with crow bar. The lower end tells you that you have only a full battery left and the alternator is offline.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 10-03-2015, 08:20 PM
Thanks for the replies.
A friend provided this information on general alternator theory.
http://ronkilber.tripod.com/alternat/alternat.htm
It contained the paragraph below which provided the magic numbers I was looking for.
"The regulated voltage (14.2) to the system bus is somewhat higher than the battery voltage (12 volts) so that alternator current flows to the battery to charge it. If the regulated output were, say, only 11 volts, battery current would flow to the bus instead, eventually discharging it. So to keep a full charge, the regulator must clamp at something greater than 12 volts, but not so high as to boil the battery or damage onboard electrical equipment. Thus, 14.2 volts (+/- .4 volts) is the industry standard for charging systems using 12-volt batteries."
He also provided the below information from the B&C web site which was most helpful.
http://www.bandc.biz/pdfs/quickfacts_lr3c.pdf
http://www.bandc.biz/pdfs/LR3C_Installation_Manual.pdf
From which came the following quote:
"The LR3C is pre-set at 14.4v (28.8v on the LR3C-28). If adjustment of alternator output voltage is needed, remove the 3/4" round plug from the side of the LR3C and use a small screwdriver to turn the small adjustment screw (clockwise to increase voltage, counterclockwise to decrease voltage; approximately 1/2 turn per .1 volt). Use a digital voltmeter at the battery for this measurement."
This was exactly the information I was looking for. Thanks to all who participated.
Steve Rush
Arlington, WA
RV-9 Tail
