Old 09-29-2015, 11:51 AM
SteveRV8 SteveRV8 is offline
Default Can someone tell me what this port is for?
https://www.flickr.com/photos/farwes...osted-public//
Steve
Old 09-29-2015, 12:24 PM
BillL BillL is offline
Curious, that is where I put my oil temperature probe. Now the question: what is the port you installed the temp sensor in? I will go look in my Lyc materials.
Bill
RV-7
Lord Kelvin:
Old 09-29-2015, 12:54 PM
DanH's Avatar
DanH DanH is offline
Common error. That's the oil temp probe port in the top of the filter adapter. Here someone has installed the oil temp probe in the top of the passage coming up from the pump. That would indicate sump temperature or close to it when the vernatherm passage is open. It won't have any flow when the vernatherm passage is closed, so I don't what you would get.
The correct temp sender port is under the red plastic cap. It is assumed to measure temperature of the mixed flow from the oil cooler and vernatherm bypass port.
The port in the background is simply capped off. There should be no viscosity valve piston and spring installed under it if a vernatherm is installed.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-29-2015, 01:08 PM
az_gila's Avatar
az_gila az_gila is offline
It should be a plug (preferred) or a plunger.
This thread gives lots of detailed info -
http://www.vansairforce.com/communit...ad.php?t=45548
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-29-2015, 01:35 PM
Default Thank you
Thanks guys, I put the temp sensor in wrong port, will reinstall plug and put where the red cap is.
Steve
