What exactly is the question?
I just took the Hartzell governor with the instructions with it and bolted it on. I used the Lycoming torque on specifications provided with the engine. Just be sure to use the gasket with the screen and point it in the direction that it fits nicely and does not crush the screen. M1B and governor from Vans. The engine case is bolted together with nuts , "the little thin ones", that came off the cover plate. Is there some reason for concern?
What are you missing?
Bill
RV-7
Lord Kelvin:
