Old 09-26-2015, 10:13 PM
az_gila's Avatar
az_gila az_gila is offline
Question What baffle part do I have?
I bought a new O-360 Baffle kit from Vans and after checking the parts they seemed to have shipped a CB-1007A "RHT.AFT CASE BAFFLE" instead of the CB-707A part (same name) that is listed on the OP-40 instructions.
It has a large oval hole in it, and a missing mounting hole near the mounting bolt -
Does anyone know where this specific 1007A part is used?
Will it work for an O-360 if I rivet a plate over the hole, or do I need a new part?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-26-2015, 10:48 PM
aerhed aerhed is offline
That's the hole for the upper left lord mount isn't it?
Actual repeat offender.
Old 09-26-2015, 10:49 PM
I meant right. I was seeing backwards.
Old 09-26-2015, 11:33 PM
az_gila's Avatar
Smile
No, it's way too big (over 3 inches) and to far away from the case.
It looks like it might be for an angled 3 inch hose flange.
Gil Alexander
Old 09-27-2015, 05:00 AM
rzbill's Avatar
rzbill rzbill is offline
Hi Gil,
That hole is for the Lord mount on a 6 cylinder. The geometry is different than the 4 cylinders and the result is the Lord mount sticks well into the baffle on the RV-10. As you corectly identified, you have an RV-10 baffle part.
Bill Pendergrass
ME/AE '82
Old 09-27-2015, 10:27 AM
az_gila's Avatar
Cool
Originally Posted by rzbill View Post
Hi Gil,
That hole is for the Lord mount on a 6 cylinder. The geometry is different than the 4 cylinders and the result is the Lord mount sticks well into the baffle on the RV-10. As you correctly identified, you have an RV-10 baffle part.
Thanks Bill, that makes sense. As always, I seem to find these things late on a Friday afternoon.
If I can find an unused one locally I guess I could use it as a template, make a new 'backplate' portion and rivet it on just above the top long bend.
Gil Alexander
Old 09-28-2015, 10:45 AM
az_gila's Avatar
The angled bit didn't look wide enough for the 2 inch hole specified in the instructions so the correct part is on it's way from Vans.
Gil Alexander
